9.5 johnson motor tag gone
backwater52
Anyway tell the year without the info tag? i know it's 6?-73 era. does it matter buying parts , not sure how many changes in those years
Post a picture.----They are easy to identify if not been painted.
backwater52
Thanks, repainted hood and all stickers gone. But checking part no.'s it is 67 or later so can figure what i need. But I'm kinda stuck about impeller/cooling. Since this has a thermostat how long should i run it before it opens up? Ran it about 30 seconds and shut it down with no water at all coming out. Has the rubber tube thru the motor case connected to the block and nothing came out.
Crosbyman
Should pump out water !! change the impeller ot inspect what is wrong
water normally bypasses the thermostat anyway .. open or not
If you do not know how old the impeller is you need to install a new one.-----This motor does not have an alarm or shut down system.-----It will overheat and run till it is too late !
backwater52
Always had 3-4 hp omc's, first twistshift i owned. got an order for parts started, still adding.
pretty sure its a 1968 Evinrude 9822D​
backwater52
After checking on other parts i see the front panel is at least 1969. this welch plug give any clue?
The paint colour eliminates 1967 as the year.----Any pictures ( 3 ) of the cowling ?
The 69 model had gold coloured decals.----The 68 models did have a wee square plastic applique if I recall.
