9.5 lower unit questions
younggun
I have a 68 Johnson 9.5 on my little duck boat and the very bottom piece of the lower unit cracked during the summer when I was out just running it and hit a rock so it drained all of the oil out. I have a 64 that's a parts motor so I took the bottom piece off of the lower unit of it and it looked a little different but everything lined up so I didn't think anything of it. Well fast forward and now the motor doesn't want to stay in forward or reverse. Reverse at all and forward if I give it more than idle throttle. Is there a different where the little arm connects down on that bottom section to change gears or is this a different problem? Thanks in advance for any help
Honorary Supreme Mariner
That lower unit is machined when the 2 parts are assembled.----Technically the lower part does not interchange.----But all parts should be in the correct position--Best is to do a complete inspection of all the parts.------Was it run with water in the oil ??
HighTrim
How did the gears and dog look when you inspected? How did it look different?
The shape of the housing looks different.----Function is the same !
younggun
Well I drained the lower unit oil today and there was water mixed with the oil after only 2 trips. I inspected the gears and dog of both and the 68 has had the water take its toll. I ordered a seal kit and new impeller for the lower unit of the 64 motor and am going to put all new seals in it since I know it is in good functioning shape gear and dog wise and put that lower unit on the 68 motor. Thanks for the replies.
