Re: 9.5 sportwin bad coil or ?
I`m running the 3 blade factory prop, Rick. The boat is a 12 ft shallow hull smokercraft, circa `71. It weighs next to nothing by itself and i can easly pick it up and move it. This and the motor which I`ve pretty much replaced everything except for piston/rings(had 75 lbs on both cyl before the decarb, have`nt checked it since) surely attributes to the decent speed. I only paid $30 for the motor, the guy i bought it from said he could never get it to run right as it had many problems- weak ign, lower seal leak, bad fuel pump, water leak in cyl from head or exh cover, carb needed rebuild, stuck driveshaft and the water impeller needed replacement. Once the weather clears and the wind dies down here in Michigan I`ll take it back out with float adj. and see what it`ll do with just me. Thanks for everyones help along the way!!
