OnLakeLawrence
Thread starter- Joined
- Jul 14, 2021
- 7
I'm familiar with why there are 9.9 engines, but can't find much info on why manufactures make a 9.8 hp motor. Anyone know? State restrictions as well? Thanks.
Yep, that is where I saw it, a Tohatsu motor. Thought I might learn something, but as racerone says, marketing might explain it.Tohatsu I think started that and other manufactures followed. The 9.8hp are tuned up 8hp variants, and the 9.9hp are de tuned 15hp variants. They are sold at different price points, and weigh differently
And those purposes are? I’m a little dense. Why would a company make two different motors for 10 mile lakes? Thanks.It's not marketing in this case. In the case of Tohatsu, The 9.9 is 333cc and the 9.8 is 209cc. They are different motors. 9.9 and 9.8 both exist because of 10hp limited lakes, but between those motors, they are built for different purposes
Bigger boats vs smaller portablesAnd those purposes are? I’m a little dense. Why would a company make two different motors for 10 mile lakes? Thanks.
The only thing I will disagree with there is the Merc 9.9 started out on the smaller block. It shared the 6/8 hp block it did not go to the 15 hp block until early to mid 90s.merc started the 9.8's in the 60's the 7.5hp and 9.8hp motors were 11 cubic inch twins. same motor, different carb.
later the merc 9.9's and the 15's were same as the motors got fatter, er bigger in displacement like the OMC product. the 9.9's getting a smaller carb
the whole thing started as a need to be under the 10hp rule for HP restricted lakes.
in fact many of the 15hp motors were re-decal'd as 9.9's as people like to cheat
@OnLakeLawrence Matt covered the needs for two different motors, and I will expand on it. the smaller displacment motor is much lighter so when you have portage, you dont throw your back out. the larger kickers work best lugging as they have more low end torque. difference in weight between a 11 cubic inch 9.8hp 2-stroke and a 20 cubic inch 9.9 2-stroke compared to a 9.9 4-stroke is 67# vs 75# vs 112#
when needing to carry the motor, light weight is everything.
reference https://forums.iboats.com/threads/w...993-20hp-and-1986-9-9hp-all-2-strokes.537607/
Thanks everyone, now I can see why a 9.8 would be desirable. Great input.
The little 9.8 Mercury motors and even the 7.5 11ci motors punched well above their weight but I always felt the lack of prop choices limited their application. They were great on small light boats where the two prop options would work. For the most part, in the earlier motors, the 9.8 came with a two blade prop, the 7.5 came with a lower pith three blade.merc started the 9.8's in the 60's the 7.5hp and 9.8hp motors were 11 cubic inch twins. same motor, different carb.
