stevenj
- Joined
- Jun 8, 2008
- 156
80/81 mercury 9.8, serial 5794858 , replaced impeller a few years back after
figuring i had an issue with overheat lack of tell tale stream, at that time
I remember finding pieces of the disintegrated impeller in the water tube,was
able to clear tube put back together and run in a barrel. noted that tell tale
stream was flowing intermittently, with t/stat removed. seemed to me to have exhaust gasses mixed in with the stream and getting very warm to the touch (water from tell tale) my hand are very rough and handle hot very well.
Put away and forgot about it .then last season pulled out, started , and was reminded of the issue stated above. put away again and began playing
with a 57 big twin 35, installing a helm and steering components in my
mirro-craft, turned out well to me.
fast forward to today cold dreary rainy and bored and dreaming of getting out fishing,remembered flow issue.
b4 putting away last year, i started with the stat cover off and felt what i feel was exhaust gas coming from the center port of casting hole , time
to order a manual and tear into this.
someone told me that there might be baffles of some sort in the exhaust cover that might be distorted. does this sound possible?
thanks for any and all thoughts.
sorry if i rambled a bit on this
steve
steve
