9.8 mercury 110
TIFTON
my mercury 9.8 110 shut off on me after about 10 minutes of running it. after it cool off it will start back up. What seems to be the problem? I have been troubleshooting the following but each of these are functioning properly:<br /><br />gas is following properly<br /><br />water pump is working correctly <br /><br />gas/oil mixture is correct<br /><br />both spark plugs have been replaced<br /><br />new carb kit has been put in it also<br /><br />could it be a coil pack or does this motor have one?
Motor Boater Bill
Re: 9.8 mercury 110
Post your serial number so we can determine which iginition system you are dealing with. <br /><br />Sounds electrical. Check for spark when it shuts down.
TIFTON
Re: 9.8 mercury 110
here is the sn#<br /><br />9.8 mercury MOTOR<br />SN #4997779
