Motor had a pee problem as it wouldn't pee, but the motor would start easy and continue to run. After a lot of cursing finally changing the baffle plate under the exhaust cover which was warped seems to have cured the pee problem but now all of a sudden it is hard to start and will only run for a short while before it stalls out. When I had the motor apart for the gaskets and and water pump I also took the carb off and cleaned it. Now like I said it was running good just not peeing, so what has changed now that I've added the new baffle plate and gaskets that is causing the motor to seem to be starving out of fuel?
