Re: 9.9 4 stroke hard cold start
Ken,
When the plunger is in the up position, the enrichment circuit is activated. It will be in the up position while cranking.
As the motor warms up, the plunger will pull down and the fuel mixture will lean out. There is a B.V.S. valve that is monitoring the head temperature that will open and close, allowing vacuum to control the plunger.
My manual has six pages explaining how this carb works.
It does mention that if you have removed the thermostat or it is stuck open, the enrichment circuit will always be on (plunger up)
There are 2 diaphragms that pushes or pulls the plunger up or down (could possibly be torn) providing the other components are functioning correctly.
When everything is working correctly, it works very well in my experience.
I wouldn't be buying a new carb just yet.
A factory manual is a must for this motor.
Scott
