FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Cousin has this engine, has the push button start on motor, tried to install key switch on console, no luck, battery wire for batt to (b) on switch, and a wire from (s) on switch to starter , no luck
i used a test light and found wire off his pushbuton thats only hot while pushbutton pressed, thats where i hooked the (s) off keyswitch, seems that shouldve done the trick, very wierd, his doesnt seem to have solenoid
the 78 9.9 is wired direct between tiller handle battery and starter. you will have to install a starter solenoid if you intend to do it with a remote key and and push button. The wires that you are running will not carry enough current to make things work right. Install new solenoid. you will need two battery cables. One from battery to solenoid and one from other side of solenoid to starter. post back results.
