This is part two of a question posted earlier this month. I have spark and I replaced the head gasket on my now un-seized 9.9 Evinrude from 1982. The compression numbers are still grim (60 and 90 psi) but I understand that it should start even with those poor numbers. It doesn't. I got it to catch a few times but there was none of the roar of power that I was hoping for. Here are some symptoms ,,, any comments (including "it's an anchor") would be welcome and appreciated.
(1) I know that the lowest compression number (60 psi) is due to a stuck ring. I know this because I removed the exhaust port cover and, after poking all the rings with a popsicle stick determined that one of them is stuck. I have used the usual things (PB blaster, mystery oil etc) to get it free but I am probably looking at a ring job but my hope is that I can get it running long enough to shake the ring free.
(2) After pulling on the starter rope a few dozen times with the throttle roughly in the spot where start would be, I got it to cough a few times and run for one or two sec or so. A few more dozen pulls and nothing. I still have spark but when I squeeze the primer bulb I think I can hear gas gurgling into the carb but appears that gas is leaking from somewhere in the carb. This is obviously a problem, where do I start ... does it mean a complete carb rebuild or could the float valve just be stuck?
Thanks for any advice!
David
David
