I have an 85 Johnson 9.9hp long shaft that I'm replacing the impeller on.Problem is that I've got 2 o-rings left and my clymer manual(for2-300hp,91-94)isn't real specific about where they go.The larger one,1 1/2"od x3/16",I assume,fits right on top of the pump housing,for ease of re-alignment.Correct me if I'm wrong.The smaller o-ring,5/8"x3/32",is the one I'm really not sure about.I read one link from the forum about it fitting into a notch by the splines on the driveshaft,but my 85 doesn't have a notch.Should I just slide it down to the bottom of the splines
