exbetterhalf
- Joined
- Jan 20, 2010
- 3
Thanking you in advance. I have a 1992 Johnson 9.9, tiller, pull start. It takes quite a few pulls to start the engine cold, sometimes even when warm. I always use StaBil in my fuel and sometimes add carb. cleaner to the mix. I changed the spark plugs. I would just love for this engine to start on the first or second pull every time. The pressure in the primer bulb stays constant with no signs of leakage. I recently bought this engine and I have no idea how well it was maintained, I do know the water pump wasn't pumping so I replaced that. That was a whole nightmare in itself as 5 out of the 6 bolts holding the lower unit broke off. It may have been in salt water. I have a factory service manual but I don't know where to begin. I would hate to start messing with things that will lead to bigger troubles. The local marine mechanic charges close to $100/hr so that is out of the question, for now at least.
Thanks again,
Tony
Thanks again,
Tony
