Engine starts and idles fine. Accelerates smoothly to max. rpm but cuts out after a few(maybe less) minutes of running. Noticed the fuel line bulb is flat and will not firm up as though no gas in line. Tried running engine at slower speed and periodically squeezed the bulb and engine continued to operate fine. Obviuosly it is starving for fuel but is the most likely culprit the engine fuel system or the fuel tank?<br /><br />For the record I've replaced the supply line from tank to engine (with new bulb)<br /><br />Any ideas?
