9.9 johnson overheats in low 1994
cruiser1
Hi great site newby here,
I have a 1994 9.9 johnson when i am in gear just idling or very low engine speed will sound overheat alarm. When i am throttled up no problem. Searched the site here and took some advise. Changed the impeller with a kit and also changed out the thermostat bought engine last year and issue may have come with motor don't know. Last owner had sitting for 3-4 years before i bought it, changed plugs and wires and rebuilt carb seems to run and idle fine except for this issue. Any suggestions or next steps greatly appreciated.
Thanks
Solittle
Re: 9.9 johnson overheats in low 1994
Is it still getting hot afte you changed the impellor and t-stat?
cruiser1
YES still getting hot in low when i am just idling arounf in forward gera.
Even tested old thermostat and it was opening at 160 degrees but put new one in anyway because of age problem still exsists.
