Fish Hawk 52
Thread starter- Joined
- Apr 21, 2010
- 9
Greetings: I am trying to drop the lower unit on a Yamaha 1999 9.9 high thrust 4 stroke to replace the water pump. Bolts under cavitation plate came loose easily, but the shift shaft (rod) coupling is seized to the shaft. I backed off the nut below the connector but can't get the shaft loose from the coupling. When I put a wrench on the coupling the whole shaft turns and I know if I put too much into it something will break. I haven't force dropped the LU yet because I'm afraid of pulling something out of the gear case. Anyone have a solution on how to break this thing loose without tearing it up?
Thanks, Don
Thanks, Don
