Finally getting everything worked out on this motor. Stator was bad and thought it was the 16 amp stator but turns out it was a 9 amp. My engine only has the small square rectifier. It is overcharging the battery. Maxed out the gauge at 16 volts. I don’t want to burn anything up. Can I add a regulator or different rectifier to match the 16 amps? Thanks for all the help
