'90 5.7 Takeoff
sstone
Thanks to help and a lot of info found here, I brought my 1990 5.7 cobra back to life after a 10 year nap. It runs great, and being a lot of motor on a 20' boat it goes pretty fast, and takes off quick. If I jump on it too hard though it hesitates for a little and occasionally backfires through the carb. Might be a dumb question but Is it getting too much or to little gas in the pump shot? Or another problem? 4 barrel Holley, I think 4011, vacuum secondary. Thanks.
bruceb58
Re: '90 5.7 Takeoff
That's a lean condition. With the engine off, look down the carb throat and see if the accel pump is squirting fuel when you advance the throttle.
Also, mashing the throttle can cause this. Don't mash the throttle.
sstone
Re: '90 5.7 Takeoff
It squirts a lot of gas down it, no problem there. Just rebuilt too. But I may have been mashing it. Has a real short throttle distance and I've never driven it before
cr2k
Re: '90 5.7 Takeoff
Power Valve. probably dried out over it's sleep. Easy to blow on a Holley. One back fire and gone. Use a high altitude or marine one.
sstone
Re: '90 5.7 Takeoff
Just rebuilt it, replaced all the good stuff, with a marine rebuild kit. It didn't misbehave any afterwards, but I'll check it. I'm thinking I just mashed it too hard
