Re: 90 Bayliner 85 force trim problem
Take off the pump body. That is the thing with the 4 hyd lines coming out of it. Disconnect the 4 lines and unscrew the 4 screws holding the body to the reservoir.
Now, if your pump has the screw in check valves, your job is easy. Using an Allen wrench, unscrew the check valves on the outside of the pump--one on each side of the pump. The quick and dirty fix is to replace them in reverse order since the up check valve seems to fail first, and you really don't need the down check valve. The proper fix is to remove the pressed on valve cap (part just above the O ring) I grab it with a cushioned pliers and twist and pull. Be careful! Don't **** it up! you need it again. under the cap you will see the check valve and the remains of the small O ring. Go buy one of these O rings in Viton and replace it. Carefully press on the cap and replace the valve assembly in the pump. If you have the pump with valves held in by circlips, these valves are not serviceable. To the best of my knowledge, no one sells replacement valves. Contact RRitt here and see if you can buy a pump from him. He will probably be jumping in here soon anyway. Pumps are his specialty.
