gydatree
Thread starter- Joined
- Jul 3, 2016
- 33
I recently installed a replacement powerhead on this outboard. It had blown the bottom piston in the old one with a bad voltage regulator. It cranks right up no problem, idles a tad rough just under 1000 rpm in the water. Once you get going at low rpms it seems to vibrate the aluminum siding on the pontoon a bit. Upon acceleration to about 3000 rpms it hesitates, but will cruise for a bit at least.
Once you try to open it to about 4500-5500 rpms it hesitates for a few seconds, but will kick in and get up to about 5000 rpms running great pushing the boat fine, but will start to die down and eventually stall out unless you pull it back to idle in time and sometimes pumping the bulb on the fuel line will keep it going, and if it stalls you have to re prime the fuel line which does hold pressure until you start opening the throttle.
There are no visible fuel leaks anywhere, and i blew out all the lines with pressured air, but now that i think about it im not sure if i pressure tested all of them. The carbs and fuel pump are freshly rebuilt with new gaskets etc.
I am thinking my next step is to pressure test the fuel lines and maybe replace the fuel pump diaphram. I tried a different bulb in the line from another boat and didnt see any difference.
So do you guys think Im close or could there could be an issue maybe with the enrichment valve or timing or ignition system that I am not linking the issue too?
