90 Honda SPEEDOMETER NotWorking. WaterTube Plugged
GWSportfish
I have a 90 Honda the speed quit working I bought a new speed guage
and put in a new hose. The small hole on the foot is plugged somewhere between the hose fitting above the inlet. I have tried to rod them out from both ends but I hit something hard on both ends. The last thing I tried was to blow air from both ends. Has anybody ever had any problem like this.
GWSPORTFISH
zzzzz
Re: 90 Honda SPEEDOMETER NotWorking. WaterTube Plugged
the only other thing you could do would be to drop the lower unit and inspect the pickup from there...there is a nipple screwed into the top of the lower that unthreads - you could use a fine wire at that point and try and clear it :cool:
