90 hp broken bolts
IkoN
I have an 86 johnson 90 hp. while taking off the exhaust plates broke a few bolts. I have room to grab but heat and vice-grips are doing in.any suggestions?
there are 4 out of 25 broke. 2 out of the 4 are next to eachother!
Thanks,
Joe
F_R
Re: 90 hp broken bolts
You need intense concentrated heat, such as an acetylene torch. Careful you don't melt it though. Takes practice.
hawkman222
I'm with F R. Lots of heat and patience. Just try to get them to move by wiggling at first before trying to turn them out. I would NOT recommend the use of easy-outs. They're as likely to break off in the bolt as they are to remove it and once you break an easy-out off in a bolt, you've just about eliminated any chance of trying to drill and tap.
KYLakebasser
If you have the powerhead off, and can lay it flat, try some PB blaster and peck on the bolts lightly with a hammer , as you spray the agent. I've had amazing results with the blaster . It doesn't work as well, if the blaster doesn't sit around the bolt long enough to penetrate, then the heats the answer.
Good Luck ,
basser
tx1961whaler
And when you drill out the bolts, here's a hint:
Screw the exhaust plate back on to use as a guide to drill them out straight.
Also cobalt bits are great. Left-twist cobalt bits are better (run the drill in reverse.
I broke a bunch off flush to the head last year on my 40. No fun, but I got them all drilled and tapped OK.
Robj
One way that I have removed broken bolts is to take the same size nut, screw it onto the remaining part of the bolt, and then get the stick welder and weld the nut onto the bolt. Gets it real hot and I have had a success rate of about 75% with this method. Sometimes you have to do it more than once.
Whatever you do, stay away from the easy outs. My experience is they tend to break and then you will have a very difficult time drilling them out.
Good luck
