Faztbullet
- Joined
- Mar 2, 2008
- 15,936
No that's the way its jetted from factory. If you pulled the black silencer cover off @ WOT on a dyno you would see a fog vapor in front of carb throat. The reason is when the reed valve closes shut a reversion pulse is reflected back through the intake flow. This pulse pushes back the charge the wrong way out the throat of the carburetor.This is why if you take air cover off it has a washed area in plastic.Do not run with aircover removed as its will lean out and a fire hazard as i twill impregnate foam in front of carbs with fuel.There a lot to airboxes restrictive and non restrictive but wont go into that...
