StingRay_90V4
- Joined
- Aug 26, 2014
- 155
So a few of you may remember a while back I had a few posts about my boat. Which is a 1992 14 foot StingRay with a V-plane hull. It has a 1992 Evinrude V4 on it. I had a few posts about the usual how to get more speed and so on. As well as a few posts about compression last summer as well. I ended up raising the engine one hole on the transom. Replaced the CDI unit it worked great just before we had to take it out of the water for the winter. However as we were getting ready to take it out of the water it started to develop a nice sized miss under WOT and wouldnt climb past 4500rpm or 30mph. We have owned the boat for nearly 5 years now. And its bottom end has always been... Ok. Not stealer... But ok. Has ALWAYS had a steady top speed of 39 to 41 mph. With 40mph definitely being the average. I will get to the timer base in a second. Just adding some background info. Lol... So over the winter our local boat shop helped us rebuild our carbs. Today I installed the rebuild carbs. I changed the bottom leg gear oil. Which looked like it was the first time it was ever changed. New plugs and a new gas tank. Fuel filter and fuel pump. At first the boat ran like carp. Then after a bit of adjustments. It ran about the same as last year. HOWEVER... While adjusting the linkages and what not. We noticed that the timer base wasnt really moving that much at all from idle to wot. So on the lake just after we floored it we moved the timer base forward to were it should be. The boat jumped out if the water like it was a 150HP on a rubber dingy compared to normal. And it smashed past 40mph and kept climbing all the way to 45 mph. And that's on a Garman GPS. The Lie-O-Meter says 47. That is a 5 to 7 mph gain by advancing the timer base to its proper spot. I would say that our 90 hp has had a sticky timer base and has needed an adjustment sense we first bought the boat 4 to 5 years ago. It has ALWAYS been more or less blah for a 90hp on a 14 ft boat. So... I guess what I am asking after all of that. Is how do I adjust the timer base properly. I much prefer to be able to hit 45 to 46 mph instead of 39 to 40 mph. As well before the boat would only hit 5000rpm at 39 to 40ish. Now.. At 45mph she is spinning the prop at 5900rpm. Any advice on how to fix and adjust the timer base properly ? Thank in advance. And thanks for reading my huge post.. Much appreciated.
