90 hp Force L drive will not rev up past 3,000 rpm under load
stevecut55
Re: 90 hp Force L drive will not rev up past 3,000 rpm under load
Originally posted by rongentersr:<br /> I have a 1990 Force 90 H/P L drive that will not go past 3k rpm under way and will not plane out. Comp check is good, fuel pump is cleen. Prop is correct. Please help<br />Thanks Ron
stevecut55
I had the same problem. Check the electrical connections on the right side of your motor.<br />Frayed wires was my problem and new ends fixed it.
