Re: 90 hp Johnson v-4 1982
Many thanks.
I will find out how the motor has been used when I open it to
replace oil seals and crankshaft bearings, where I felt a little play, and will be in touch again to discuss, Its a pleasure with you.
I would ask about the numbers of the cyllinders and the firing order;
for example; upper right hand side - 1st, upper left hand side 2nd, lower right hand side 3rd and lower left hand side 4th, when facing the spark plugs, and
firing order 1, 2, 3, 4, or something like that.
Thanks.
