90 hp leak
avantifishski
Re: 90 hp leak
shud I hook the kill switch back up then do spark test again?
avantifishski
Re: 90 hp leak
I pulled it for the compression test was this good? all 4 came tested at rite around 95#. so I was thinking this compression test a success now should it be closer to 125?
boobie
Re: 90 hp leak
Hook the kill switch back up to do the spark test !!
Bosunsmate
Re: 90 hp leak
hook it up for spark, unhook it for compression.
Those numbers seem ok, all even
avantifishski
Re: 90 hp leak
yes there even but I started thread to diagnose the excess oil leaking from different places. so I thought we were doing compression to see if it is low enough to support bad head gasket diagnoses. So with those numbers what would you gentleman say?
Bosunsmate
Re: 90 hp leak
ive lost track sorry
but compression seems ok to me.
how was spark?
wheres oil leaking from?
Bosunsmate
Re: 90 hp leak
not good
starter sounds like its slowing too, you need a lot of rpm to fire properly, it should be sparking right through that even at beginning with good rpm
boobie
Re: 90 hp leak
Have the battery load tested and then check all the cable connections for being clean and tight.
