Re: 90 HP Won't Turn Over / Plugs?
1. The circled items are the starter solenoid and the primary fuse holder. If you use the zoom feature you'll be able to see it more clearly.
2. The remaininder of your response was covered earlier.
Let's get some terminology straight.
Won't turn over means the starter is not cranking the engine.
Cranking means the starter is spinning the engine.
Cranking and turning over are therefore the very same thing.
"Won't start means the starter is cranking the engine but it "won't start".
The item you have circled looks to me like its the main engine to control box harness connector. Cranking issues are very often bad battery cable connections on the battery or at the engine. Disconnect both ends of both cables, make them shiny clean and reattach them tightening them securely.
