Re: 90 Johnson GT150 - Slowly dies from WOT
Sorry, been busy...
Regarding motor mounts: I can't find them from that diagram; the pic breaks down too much when I blow it up to see it. Basically, there are bolts that hold the it all together where it pivots, and those are isolated with rubber bushings or whatnot, and those rubber parts are broken apart & gone. It appears that the motor had a chance, high-speed encounter with an immovable object in the past, and lost. I'm not going to spend that money until the dying issue is resolved.
Regarding dying from WOT: I have gone so far as to almost replace the fuel pump, when I was given the last bits of info I needed to check the carbs to see if they had some gunk in them that could be doing the deed. And last night, I had a tournament, and it started to die from WOT. I pushed in & held the choke, and it would lose power, then gain power, then lose, gain, lose, gain, etc, and got me the last 1/4 mile to our first hole. I'm now convinced it's carbs.
Thanks!
Sorry, been busy...
Thanks!
