Yep, that's ol' reliable taking off with yours truly behind the yoke.Howdy,
I have seen them on ebay before. I'm sure you know you would have to change front crank pulley to the "right" one etc.....
You would also want to ensure that the PS and alt have the right brackets etc....
Is that you flying that 182 in your picture?
Cheers,
Rick
Yeah, I was thinking about changing everything. I've done that conversion in a few hotrods but never in a boat.
Thanks for the link.
Ayuh,... I don't see it as an Up-grade either....
With the Serp. belt, if it breaks, you're done...
With the V-belts, if 1 breaks, you're only out that particular component....
You'll have to find a later model motor,+ strip the Whole front of the motor, to get All the bracketry.......
Including the reverse rotation waterpump....
A 182 is a great airplane!! of course the tailwheel is on the wrong end but that's just a preference!!
I would love to do a serp on my 454 but it does require changing a lot!
I figure it would be easy enough to carry around a spare belt...if I'm replacing all the accessories anyway...hmmmm, is the GM performance serpentine setup w/o A/C the same setup? Of course the actual accessories would be different.
Eh, may not be worth the hassle....
I've owned a 1947 Stinson since 1981.....and my "hobbie" job is involved with flying.Do you fly too?
It is if you can scrounge the parts to do it. A serpentine belt is far more reliable (IMHO) than multiple V-belts and MUCH easier to change if it does "break". They'll last far longer than you should ever run one.
okay Ed, I gotta ask...what the heck happened?I`d think the belts are better.Most use 2 belts .P/S can afford to be missing but the other runs everything else .And on most motors it`s not that much of a pain to change.
Yep, I used to fly the Yak-52 till some trees got in the way
Remember that the circulating pump turns the other way with a serp belt, gotta replace it.
How come every time you go to a party everyone always ends up knowing who the pilot is???
