90 Mercury 40HP motor
warddog
Bought a 20 ft pontoon to use on our pit and it came with this 40 HP motor. It is a 1990 Merc. 40HP, ELPTO, 4 cylinders with a serial number of OC226261. It is oil injected. Pulled it off as it is too big for our use and decided to have it checked out at the local marina due to having sat for approx. 12 years or so. They checked it for compression, fuel and fire with the results saying it had compression of #1=120, #2=120, #3=110 and #4=95. #3 and #4 have scored cylinders. It also had no fire and a horn going off. I don't know what No FIRE and a horn going off may be but do know that scored cylinders would mean, tearing it down. I have wrenched on a LOT of stuff but never an outboard motor and I figured this was enough to not be worth putting any money into and curious if my thoughts were correct? I do have the service manual for it. I brought it home and figure I may just part it out.
Chris1956
You might stick a bore scope into the bottom two cylinders and see if the cylinders are scored, or if the rings are stuck. Sometimes when motors sit for a long time, the rings stick. Sticky rings can be loosened w/o disassembly.
Not that I don't trust the shop, they may have been too busy (lazy) to check it.
As for the spark, you might check the condition of the wiring harness. Merc has issues with the harnesses going bad and the insulation falling off. I would think this issue was fixed by 1990, but That motor is an older design, so who knows.
Texasmark
Before you go to a lot of trouble, get some Sea Foam (auto parts stores have it) and put 2 oz. per gallon in your fuel tank in addition to any pre-mix requirement. Run the engine till that tank of gas is gone. If you still have a problem, then "I" would start looking into engine problems requiring things to be removed and inspected. I just have the motto: Don't fix it if it "ain't broke!". My experience over the years is that it has saved me a lot of fooling with stuff that was acting up but not "broke".
airshot
I have a 1992 version of that motor and love it. Been one of the best running motors I have ever owned. Whether your's is worth putting money into it, is your call, but ....from all that I researched before buying mine, they were great, reliable motors. Smooth idle, so slow you can hear each cylinder fire and mine will outrun any other 40 up I have owned and I have owned quite a few.
warddog
I suspect they plugged some sort of diagnostic
I suspect they put some sort of diagnostic reader into the wiring harness and didn't do much more than that. Might have put a bore scope into the #3 and 4low compression cylinders to see scoring as they did specify, they were scored. Looked like pretty general statements and not much in-depth checking.
halsteadmorris
My 1996 4 cyl ELPTO40 has been the best motor I've ever owned. Delete the oiler, run them often, and they are bulletproof. Despite this, I have not found them to hold their value the way that 80/90's Yamaha 2 strokes - undeservingly, in my opinion - do. You may be better off selling or keeping it for parts and purchasing a better condition one for 1500-2500 (in my area). I have found parts for this model harder to come by and more expensive than other motors of the same vintage and aftermarket options to be of poor quality.
In my experience, neglect kills 2 strokes more than overuse or abuse. Once they sit for a few years... or months... the gaskets and hoses dry up and the carbs clog and stick. You wind up either playing whack-a-mole with the fuel system, water pump/jacket, and wiring or biting the bullet and doing a full rebuild.
Fix her up, run her often and hard, and she'll do well by you! That said, pick your battles wisely...
warddog
I doubt you can use a " diagnostic reader " on a 1990 4 cylinder Mercury !
I don't know but the electrical harness was unplugged in the motor and the diagnosis was as stated above. No fire and a horn going off made me think maybe a reader of some sort.
warddog
I have had some local inquiries about parting out this motor but I know nothing about it. The marina stated it had power trim but didn't say anything about tilt. Beings I have no idea what is what on this motor does it have both power tilt and trim or can it have one or the other? Any idea of a fair price for such?
airshot
I have the 1992 version of this outboard, oil injected and never an issue. Yes the magnet came off the float in the oil reservoir so that alarm is dissabled, but I simply top off the oil tank when I fill my 18 gallon fuel tank.
As far as parts go, no problem, local marina/ parts depot has anything I have needed so far and anything "boat" related is expensive, so already numb to that scenerio. Mine has been a garage queen since the day it went into service, so it not only looks like new, it runs like new and it is used from May to November every year. Take care of them and use them and these old two strokes will run forever ! I recently did a little research.....a new model 2025 40 hp Merc four stroke is rated to use one gallon less fuel per hour than my old two stroke....a new motor is around 8K.....how much fuel would I need to save to pay for that new motor, and will I live long enough to get that payback ??
These 2 strokes are just great motors.----But many shops now refuse to work on them for various reasons.----They encourage folks to buy " new technology " and spend big $$$-----they improve the bottom line for many shops.-----In my opinion the big 4 strokes are like fancy sports cars.-----Fun to use but expensive to maintain.
airshot
Due to the popularity of walleye and Perch fishing, boating is extremely popular in my area. We have no issues finding people to work on two strokes. Most of the bigger marina's stay with the bigger four strokes but plenty of smaller service places to get your two stroke serviced as there is a large number of these still on the lake. No one is saying the service is cheap, but it is availiable. If people would take the time and effort to properly care for these motors, they would not need expensive repairs.
I see what my neighbors spend, just on maintenance each year for their four stoke outboards. To each his own, but can't beat the low cost of a good ole two stroke....
