Re: 90 mercury firing order. 3 cylinder 2 stroke
Gator, you really have to start answering some of our questions if you want help. Did the ignition parts from the old powerhead get transferred to the new? Or did the new come with that stuff?
I don't know what year my old power head was. Early 90s I think. I fish commercial so it's been replaced before. I burnt a piston and got a deal on this new powerhead. Serial number on my flywheel is 9007.
Hmm, could be a mish-mash of parts years on there then. Some quick web research indicates that there were a number of changes in part number for the stuff that is on topic here (block, crank, flywheel, trigger, stator) in the Merc 90hp 3 cyl's right around 1993-94 (probably to to accomodate a change to 1-3-2 firing order), then another change in most of the ignition part numbers in mid-1996 (for what purpose, I dunno, maybe to swap trigger firing order to avoid crossing wires over at the coils? Maybe they included one of those idle stabilizer doo-dads?). They all supercede to different current part numbers, so you basically got three groups of ignition parts:
1) 90-93
2) 94-mid 96
3) late 96 to about 98
And two groups of block/crank parts:
1) 90-93
2) 94-98
If your original powerhead is 90-93, and your new powerhead is a 1996 (or actually 1994 and up), I am thinking you might need to acquire newer ignition parts. It is very possible that the mounting area on the top of the block where the trigger rests changed between 93 and 94 (and/or the location of trigger magnet in the flywheel, trigger points in the trigger, their relationship to the timing decal and the timing pointer, all sorts of possibilities), and thus a pre-1994 trigger and flywheel (which I am assuming you are using) may not allow you to set timing accurately on the newer powerhead.
So how about for a start we try to figure out for sure what years the original motor was and the new powerhead is. Perhaps the original motor has a serial number plate riveted to the clamp (up on top of the tilt tube area), and perhaps the new powerhead has a serial number stamped into it somewhere.
