snapperman
- Joined
- Aug 9, 2002
- 35
Hi I have a Johnson model BJ90ELEDR, I can not get the trim to work. <br />The list is what I have done<br /><br />Checked all connections <br />I have power to both the control box trim swith and the motor trim switch. I have tried new relays. I can by pass and jump the relays and the trim motor works fine. I have checked all the connections under the cowl and connot find the problem. The relays won't even click. Fuse has been replaced. I have ohms testet all the connections. And cleaned all earths <br />What I did before I had this problem was check the connections as I had no Tach. Also as I had no tach the battery appeared not to be charging, Does anyone know what I can do from here as I am lost. I've even tried a replacement Tach and unwired the trim guage (no luck)
<br />Battery is also charged and starts the motor fine<br />Hope someone can help <br />Thanks <br />Snapperman
