Re: 90hp block is damaged and I need some advice
I worked for 2 rebuild shops and many times had cases like this from corrosion and repaired with success by welding,then using an 80 grit paper on a marble block to deck it level.I tried many epoxies and sooner or later found it failed.There is a permanent fix ,but costly.The make a "flanged sleeve"the old sleeve comes out ,the new on has a shoulder that is equal to to total widith of mating surface,that is the thichness of the metal flange and the alum .cast you need repaired.That process requires total disassembly ,not worth it
