Re: 90HP EVINRUDE GONE BAD
Sporthog2,<br /><br />The cheapest thing to do is remove the cyl. head that has the two bad comp. readings. If the cylinders are not scored, you may just have stuck rings like Schematic mentioned. If they are scored, you might as well have it bored and re ring all four. Along with bearings, seals, gaskets, etc. I would also rebuild the carbs. that may be the reason they scored to begin with.<br /><br />Or, you just might be lucky and all you did was pop a head gasket.
