I pulled this 90 out of storage and have been workig on it for a few months now. I came to crank it up for the first time last week and it immediately cranked and reved constantly wide open until I killed it. Then cranked it again with same result wide open, not even close to idle. Pulled the carbs which have been thoroughly cleaned, re-adjusted the floats, fresh gas, and changed the needle and seats in all three. Yesterday cranked it to see if I had solved the problem, but disappointed with the same result of immediate surge to wide open rpm range. Throttle cable was disconnected but problem wasn't solved. Any ideas?
