90HP Merc Idles in water, not on muffs
efdog
I've got a 1997 90HP Mercury 2 stroke.Any posts I've seen all seem to be the other way around. Well I idle fine in water, but when I come home to flush, it runs for about 2 mins, then stalls. I'm thinking it must be a water pressure issue, but would that cause me to stall. It's peeing good right from the turn of the key, so I wouldnt think it's overheating. I can wait 10-15 mins and restart, but get the same thing. Dies in 2 minutes.
Anyone ever hear of this problem?
efdog
Re: 90HP Merc Idles in water, not on muffs
Nobody has heard of this before? Really I just want to make sure that I'm not doing any damage. Any reply is greatly appreciated.
Barnacle_Bill
Well it is certainly different. I'm wondering if you are turning the water pressure up too much. It shouldn't make a difference but it doesn't need to be turned up high.
j_martin
Water pressure doesn't make much difference, but water temp might. That coupled with slightly stale fuel, and it might lean out at idle. You might fuss with the idle mix adjustment. Just remember where it was so you can put it back if you don't make any change, or you get it to idle on the hose and not in the lake.
milehighboater
are you running on a slanted driveway or flat ground?
bullet 101
Its because when you use muffs the exhaust doesnt have any backpressure;)
roncoop75
That would be the other way around wouldn't it? He's idling WITH the back pressure, won't idle WITHOUT the back pressure.
Usually it's the other way around.
efdog
Thanks for all of the replies.
roncoop75, yes that's correct. I'm idling great, never stalls on the water. No back pressure, and it stalls out in a couple minutes.
milehighboater, yes my driveway is slanted slightly. I'm tilting the motor all the way down to get it as eye level as possible, but I suppose it's probably still on a bit of an angle. Could this be my problem?
j_martin, fuel is good. Well water is ice cold, just like the Saint John river where she idles great. I dont want to mess with the mix adjustment in case this effects how I'm idling with back pressure...it does seem to be fuel related as it has the same effects as flooding when I try to restart, and similar to flooding will restart in 15 mins or so.
j_martin
It's probably idle fuel mix, that happens to be perfect with back pressure, and a little lean without. If it were a bit richer it might run in both circumstances, but you would probably be a bit rich on the water.
If it idles, and accelerates well, I'd just leave it alone and set the warm up lever up a bit while you're rinsing it out. If acceleration is a bit sluggish, it'd be worth the trouble to set the idle mix a bit richer. Probably would solve both problems.
Normal idle setup is quite rich to provide some of the fuel needed to get it wound up at the hole shot.
hope it helps
John
jimg984
exhaust fumes may figure into the problem
bullet 101
More than likely there is no problem at all. some outboards just wont idle without backpressure
efdog
J martin...thanks, I think I may need to richen up a bit, as it does stumble a bit upon acceleration, and can be a very rough idler, even for a 2 stroke. To make a very small adjustment, do you think 1/8 of a ccw is going to help? If so, should I turn all 3 scrrews?
Thanks for everyone's help!
