91 Force 150 on Trophy 21ft Ignition switch wiring help
Bradforce
Hello I need help wiring an ignition switch. The terminals on the swith are marked as follows S C A M M B The wire colors are
Black
Yellow/black stripe
Red/purple stripe
Purple
Black/yellow stripe
Yellow/red stripe
Can someone please help Thanks Brad
roscoe
Re: 91 Force 150 on Trophy 21ft Ignition switch wiring help
,ooops,
roscoe
S - start - yelo/red
C - choke - yelo/black stripe
B - battery - red/purple stripe
I - tach/accessory power - purple
M - magneto - black/yelo stripe
M - magneto - blue/black stripe
Ground - black
heat alarm - orange or tan
Bradforce
thanks But where does the black go on the swith S C A M M B?? and what does the a stand for???
roscoe
The black ground doesn't connect to the switch.
It usually connects to a terminal strip. And is used as a ground (neg) for the gauges and accessories.
Bradforce
I do not have a blue wire. I have as follows
Black
Yellow/black stripe
Red/purple stripe
Purple
Black/yellow stripe
Yellow/red stripe
The Black/yellow stripe there are 2 and they are together. If I dont hook up the black I have an extra terminal on switch.
roscoe
Sounds like someone replaced a wire.
