justchecking
- Joined
- Oct 1, 2010
- 152
Re: 91 Mercury 115 Rebuild - Let's see how it goes!
It's going just fine!
Not sure I should resurrect an old thread, but this is a thread I started and haven't finished. Apparently this will be a 3 week project spread over 3 years.
During the last installment I discovered I had received the wrong piston and rings and was waiting on the correct ones. Those came and then summer happened again.
I started reassembly last weekend. I put in the new piston and rod and new rings on the other three, put those in the block with the new bearings. That wasn't too difficult, but putting in the piston pin retainers was difficult. I finally figured out how to do it with needle nose pliers and a little finesse. I'm waiting on some fresh crankcase sealer before I button up the crankcase.
Tonight I tore the fuel pump apart to clean it up and put in the new gaskets. AND I found another assembly boo boo during the 2009? rebuild. One fuel pump gasket diaphram was assembled in the wrong order and the other diaphram is for an engine WITHOUT oil injection. You can see the bulge where the oil was pushing on the diaphram but without the holes to let the oil through it just bulged.
How did this engine ever run on the water?
This was a freshly rebuilt powerhead with new #3 piston and rod and all new oil injection components manufactured in 2009 (going by build dates on various stickers).
