duke3478
- Joined
- Jul 20, 2009
- 58
Hi, pretty new to the forum, learning a lot and really appreciate the help.
I'm replacing the lower shift cable on my 91 Four Winns. Following the manual (the good one, not the aftermarket) and I can't get the new cable to go in through the hole in the transom.
I've tried going in from the bottom, out through the top, soapy water all over the plastic casing, grease, and silicone lube. The hose it runs through seems to have one hell of a bend near the bottom. The cable will thread about a foot, then hang up, and with a little more pressure, goes in another 6"-8" and hangs up again.
I've tried it with the inner cable installed, and with it out, with a plastic casing and without. Nothing makes a difference.
I've threaded a fishtape through and tried to pull it through from the bottom, and pull it up from the top. Nothing works. I spent about 6 hours just trying to make it work yesterday. I'm no stranger to unexpected problems, but this one is driving me nuts. Please help!
