RVFR
Thread starter- Joined
- Sep 29, 2021
- 18
I just got a 92 sea swirl 188 spyder on what seemed to be a deal, it looks for the starters a nice fun boat. It has an OMC Cobra 4.3.. which by all accounts is 190hp. ? What I am curious about is and from what I've read here and there that the 4.3 has a somewhat lower RPM in regards to WOT, I'm reading a range from 4200 - 4800rpms depending on conditions. now granted I got this with a couple of hic-ups that I worked out, so off to the water we went. Knowing this hadn't been in the water for over 6 years had me at bay in what to expect, with a knicked-up aluminum prop of 14.5x19, 4 adults, full fuel, and sorta trimmed out on a freshwater lake I saw 4300 RPMs on the tach. No telling what the speed was, though it felt low 40s. I also felt it should do better. ?? Second trip out on saltwater after taking care of a couple more Hic-ups like fixing the Speed-O and getting a SS Michigan 14.5x 19 prop, this time 3 adults, 1/2 tank of fuel, this time I saw 4400rpms at 45 mph via speed-O on kinda light chop of 6"-8" also trimmed as best I could with a feel thing. I'm wondering if this is pretty normal? on that outing we also gave a try at fishing which means in this case we trolled leaving the engine at idle while in gear. which seemed to be ok, until, I wanted to go. LOL when I pushed the throttle forward it coughed and spit then died. Granted we were in that mode for a good 40 minutes. Yet thinking it should do this all day without much trouble, after a bit of starting and running on 2-3 cylinders by the way it ran then dies. I finally got it to do 2000rpms even at that if I thought about moving the throttle it would crap out it did this like 3 times before I left things well enough alone, but after like a 1/2 hour of this it started to run as it did, so my thoughts are I loaded up the plugs? So now I'm looking into what's the what here. Thanks for your time what a site full of boat info
