92 Evinrude 48hp spl
llewis01
Hello and Happy New Year,
I need to know how to get the steering bracket off. I finally got the lower unit off. The steering bracket has to be replace because of the bolt for the tilt bracket broke off and the trim assist cylinder is cut off with the bolt siezed up. I can't find out out how to remove it. Really need help on this.
Thanks
James R
Re: 92 Evinrude 48hp spl
I agree. However you will need the motor hanging from a hook to remove the transom mount side plates. This will give you access to the pivot pin that I think you are referring to. If you go to a parts site B.N or BRP you can see the parts drawing for what you are doing.
llewis01
Thanks for all the responses. It turns out it will be a lot of work.
