Re: '92 Force 150 O/B problem
Ok. Generally boat is running fine. Tried to isolate why the timing is still so far off. Did the following:
1. Removed flywheel. Checked trigger coil and trigger magnet. No apparent damage.
2. Put flywheel back on. Key in place. Checked TDC with piston position and flywheel marking - zero on flywheel corresponds with piston TDC.
3. Unhooked timing block adj screw from trigger arm. Moved trigger arm to furthest position clockwise.
4. Checked static timing with timing light and cylinder #1 -18 degrees BTDC. Expected zero.
5. Marked flywheel for TDC on remaining 4 cylinders. Checked with timing light - same offset - about 18 degrees BTDC as best I can estimate.
6. Put it all back together - same result - 18 degrees at idle and something like 45-48 degrees at WOT static.
So here's my thoughts:
A. Trigger magnet slipped on flywheel. Seemed tight. Picture attached. Gap in trigger magnet offset from keyway by a small amount.
B. Timing light bad? It is a 30 year old inductive light...
C. Don't think its the thunderbolt ignition pack since all 5 cylinders seem the same?
D. Don't think its the trigger coil -same reason?
E. Trigger coil wiring seems ok. Again - miswiring would not introduce an 18 degree timing difference - shouldn't it be much worse if miswired?
So, what would you suggest next?
Thanks,
