Ok, my Dad has ended up with a 1992 Force 150 (Model 1508C92A / Serial 026716) that was "supposed" to be in good condition other than a broken cavitation plate and skeg. But, after removing the lower, the water pump housing has been glued/rigged back together and the lower unit is out of oil because clear silicone was used as a fix to a leaking propshaft seal. Also, when turning the prop by hand with it in gear, there is about 2 1/2 to 3" of "slop" at the tips of the prop blades.
Because of the prop slop, useless seals, broken cavitation plate, and broken skeg, it seems a new/rebuilt/used lower is in order. So, here's where the questions start.
Just what lower unit does he need? One site has listings for a type A,B,C,and D, but I can only narrow it down to a C or D. It has the water intakes in the normal location (not down on the side of the propshaft cone) and it has the rectangular anodes on each side near the top of the lower unit. Also, the skeg does not run forward all the way to the front of the nose. So, I'm assuming it's the Chrysler design, not the Merc, but I've gotten quite confused with all the differences in these drives. Being a Mercruiser man myself, the whole outboard situation is actually confusing!
When looking for a used lower, are there any other engines that share this same lower such as a Force 125 or even other Chrysler or Merc engines?
From some of the prices I've seen so far, he may be money ahead to find a good Johnson/Evinrude and throw the Force on eBay. After all, it did run good on the hose when he first bought this project boat.
Any and all help narrowing down what fits or finding another lower would be greatly appreciated. Sorry for the long post.
