92 Johnson (vro) 120hp Removal Of Oil Injection
amoore51
How do you disconnect your current oil injection set-up(VRO) and use your existing pump as a fuel pump only. I think I wanna pre-mix the fuel because of the horror stories I have head about the (VRO) set up. What do you think? How do I set it up?
ezeke
Re: 92 Johnson (vro) 120hp Removal Of Oil Injection
Mix the fuel and oil in the tank 50:1 and run the motor until the fuel mix has reached the engine;
Disconnect the two wiring harnesses ( 1 from oil tank, 1 from fuel pump);
Plug the oil line at the pump and clamp.
The fuel pump amphenol plug is usually tucked behind the PT&T relay box. Seal it with RTV so that it can be re-used.
