LukeFishWalker
Thread starter- Joined
- Jul 23, 2015
- 95
When I first got this used outboard it would run in the 5100 range with 12p wheel.
Then, after using it with very little problems I started noticing that at WOT it would
sometimes drop to 4800 for 15 - 20 seconds and go back to 5100.
Now it stays at 4800 even after switching to an 11P wheel.
Compression is still in the 115/120psi range, timing is correct 25BTDC at WOT,
no air in the fuel lines, new fuel pump and it delivers a good stream when jerked
off the barb while running, cleaned the carb and it was spotless.
However, upon disassembly I failed to screw in the air/fuel jet to determine the
exact revolutions of the air/fuel jet and I now wonder if I have it set properly.
When at idle, there is a pretty fair amount of degrees of turning both ways
(Guessing 270degrees) before engine idle is affected.
Should the air/fuel jet be set more towards closed or open?
Thank You For Your Time & Patience,
Lukus
Lukus
