92 Mariner short continuous beeping
92mariner
I have a 1992 Mariner That i just bought last year. it beeps twice before it starts and today it started beeping continuously once it started. Is this the Oil or Cooling system? Thanks
sharkcat
Re: 92 Mariner short continuous beeping
short beeps means oil is it using oil when you run it? if so its probably a faulty sender in the oil tank, with the engine running disconnect the wire from the tank if the alarm stops youve found the problem.To cure youll have to buy a new tank.<br />Continuous alarm is overheating
92mariner
Tnak you. How long can you run it before it freezes/locks up, or causes damage?
sharkcat
If you are worried that the oil injection isnt working fill the fuel tank with 50.1 premix & run it on that until you have solved the alarm problem<br />The extra oil wont hurt it will probably smoke a bit more but will protect the engine if the injection is faulty :)
92mariner
Thank You. I'll try the pre-mix and go from there. Thnks again for you help.
