92' NS90A float question
Snap43nib
Anyone know that proper float leavel on these things, and how can they be adjusted?
TOHATSU GURU
Re: 92' NS90A float question
You would bend the plastic tab if they needed to be adjusted...Which they almost never do. If it isn't level, it is much more likely that the needle is worn and needs to be replaced.
Snap43nib
one float is level the other 2 are the opposite way than if the needles were worn? I guess I will try to adjust them tonite,
Thanx
