'92 OMC 115 HP VRO Quietrider won't rev up under load
projectDr
OK, I'm stumped so far. I've got a '92 OMC 115 HP Quietrider VRO (V115SLEND) that idles fine but won't rev up under load. Seems like I'm stuck in SLOW mode in that I can't rev up past 2500 RPMs under load, but it will rev up smoothlywith no problem past 2500 while in neutral or even in gear when running it with earmuffs out of the water (No Load). I checked spark with a timing light w/o a load and there was spark to all four cylinders so I'm assuming the coils are OK. (But, I haven't done so under load yet) I Tested the alarm horn to both temp sensors and the alarm horn works OK. Additionally it seems to run at a reasonably cool temp. (I did change the impeller when it was rebuilt because I was getting an alarm after running it a few minutes on earmuffs during flushout) I do get water coming out of the pee hole OK and it doesn't overheat at all in the water at any time. I also disconnected the leads to the temp sensors and that made no difference under load. Runs a bit rough like it might have an inconsistant miss while under load but runs smoothly back @ idle. (even in gear)
Here's some background...
I had the powerhead fully rebuilt professionally a little over a year ago. New pistons, parts etc. Carbs rebuilt then too, and it generally ran OK initially with the exception of a bit rough idle (but I was running double oil (Oil in gas as well as the VRO tank) during the break in period. I was diligent in varying the speed etc during break in but in total I have run it maybe 8-9 Hrs total since the rebuild. (Trailered & Garage kept in between uses)
Last two times I've taken it out I couldn't get it to rev up under load with one exception where it started to rev up past 2500 RPMs while running @ WOT . (Figures I'd be in a slow speed zone then so I couldn't "let er run")
Since that one time pickup" occured I figured perhaps I had fouled plugs or something related to having run double oil in the past so I pulled the (new Champion QL77JC4 @ rebuild) plugs, cleaned them well and reinstalled them. Started up @ home fine and idled well. Next trip out I experienced the same SLOW type running situation occuring. It burns a lot of fuel too during a run @ WOT even though I can't get it past 2500 RPMs. I even cleaned the plugs half way thru the short river trip but it made no difference on the return trip. One more thing. I pulled the air intake hose off while running @ WOT and the RPMS did surge up a little when it got some additional air. I assumed that was because it was running so rich @ WOT and due to the fact that the very rich exhaust fumes were choking it out a bit in the closed up QuietRider housing. I've been load testin it with the cover off to ensure that it's breathing OK.
So, after that long winded tale of woe is there any suggested path I should pursue next? Maybe check the spark from each coil while under load?
My next thought might be to pull the carbs, but since nothing changed after the rebuild I'm guessing that they might be a lower probability? I think I've also ruled out the fuel pump by pumping the bulb while running it under load @ WOT (No change positively or negatively)
Any ideas?
Thanks in advance for any suggestions!
