92 Seadoo Electrical???
Bone1099
First i thought my problem was in the carb so i posted Seadoo Carb Tuning
Further runs seemed to get away from carb problems and into ignition problems
Sometimes when it would start easily and run kind rough so i thought it was carb and sometimes sometimes it would not even hit so i checked ignition and it was not firing. Checked connections in the electrical box then it started working normally. shortly thereafter it wasnt firing again. so i grabbed my test light and checked power to the coil on a black wire with yellow stripe while firing the test light would pulse. when malfunctioning no pulse. this wire is split into two at the coil. So I disconnected the one coming from the rectangular black box (Potted electrical with two relays on top) after disconnecting it fires and runs great but kill switch and safety switch will not shut off engine it has to be choked out. Safety switch still prevents starter form turning when cap is not installed. With engine running touching the afore mentioned wire where it was disconnected immediately kills engine.
I really need an electrical schematic so that I could know what does what. Anybody got any insight on this kind of problem. or a wiring schematic would be nice.;)
Bone1099
Re: 92 Seadoo Electrical???
Anybody here familiar with Seadoo manuals.net I just found the site haphazardly these guys have free pdf downloads of factroy manuals.
