fjcruiser8
Thread starter- Joined
- Apr 22, 2012
- 3
I have spent a few hours searching this forum and my repair manual for possible answers, with no success so I'm hoping one of you has had a similar problem? and a solution.
My boat sits in the driveway for a week or two? I decide to go fishing so I load up and check it over, which includes turning the key to make sure the battery is ok. Usually it fires right up, without the choke, opening the throttle or even priming the fuel. I drive down to the ramp 5 minutes away or 1 hour away depending on where I'm going that day, stick the boat in the water and the motor cranks and cranks, won't fire nothing!!
If I go to wide open throttle and make sure the fuel is primed using the choke, after awhile it will start, but not without a fight. Once I get out and warmed up, the motor starts right away (turn the key to engage the starter, running!) motor runs great lots of power ( pushes my 16' out of the water no problem) runs about 30-32 mph without any problems.
Since I've owned the boat ( about a year and a half) this has been going on. I have adjusted the carb screws a few times pulled the carbs and cleaned them, replaced the water pump, (nagging suzuki telltale problem had me worried) replaced the fuel hose and primer bulb, checked the fuel delivery hoses filter etc, just did a compression test (very good results 145-150 across the cyl's) checked the ignition leads and spark strength etc.
I have two possible causes for this problem;
1- Carbs needle valves are not seating flooding the engine while trailering
2- problem with vacuum (cold engine) causing fuel delivery problems (reed valves??)
The other thing I noticed was the P/O had a can of ether on board, when I first looked at the boat he never used it for starting??
Thanks for reading
Thanks for reading
